2000 Ford F350 Replacing Clutch Slave Cylinder
2000 FORD F-350
115,000 MILES • V8 • 4WD • MANUAL
CLINTFB
  • 4 POSTS
My transmission is hard to get into reverse or 1st after driving awhile. It appears to be the slave cylinder as the fluid level is ok. It is a one owner with excellent care.
Do you have any tips to make the change out easier?
Aug 20, 2010 at 1:36 PM
WRENCHTECH
  • 20,761 POSTS
I wouldn't jump to that conclusion. The only thing that goes wrong with a slave cylinder is they can leaks. If you have an issue with insufficient throw, that would usually be a master cylinder problem but I would recommend changing both at the same time anyway.
It could also be a mechanical issue with the pressure plate.
Aug 20, 2010 at 1:50 PM
CLINTFB
  • 4 POSTS
wrenchtech, thanks. but can a novice change the master cylinder and slave cylinder on the f350
Aug 20, 2010 at 2:05 PM
WRENCHTECH
  • 20,761 POSTS
This isn't rocket science but it does take some mechanical ability. Bleeding the system after can be quite difficult sometimes.
Aug 20, 2010 at 2:23 PM
CLINTFB
  • 4 POSTS
WrenchTech:
But the clutch master and clutch slave are self bleeding, right? If so, will I get into the actual bleeding as though it were a brake job?
Sorry for all the questions but I do appreciate your help.
Aug 20, 2010 at 3:39 PM
CLINTFB
  • 4 POSTS
WrenchTech:
Being a hydraulic system, there is not a clutch adjustment rod, or is there?
Aug 20, 2010 at 3:43 PM
WRENCHTECH
  • 20,761 POSTS
No, they are not self bleeding and they are much harder to bleed than a brake system because the bleeder is at the bottom and the air tries to rise to the top.
No, there is no adjustment, they are self adjusting.
Aug 20, 2010 at 4:11 PM
CLARKPEREZ2334
how to diagnose a problems related to the [URL=http://www.thepartsbin.com/brands/adler/adler_clutch_slave_cylinder.html]clutch slave cyclinder[/URL] operation? Does anyone here has a step by step guide on how to replace it and bleed the air out of the system? Any help is very much appreciated. Thanks
Aug 31, 2010 at 10:09 PM
TECH1FORD
  • 102 POSTS
you can stand there for hours trying to bleed it out, it has to be pulled from the truck and hung upside down to it. or go to Ford and order part 2c3z-7c522-e it is complete already bleed and works the first time and that part number is for that truck
Sep 22, 2010 at 4:49 PM
