2000 Ford F350 Front hub/bearing won't break loose.
2000 FORD F-350
MWHITS
Drive Train Axles Bearings problem
2000 Ford F350 V8 Four Wheel Drive Automatic
I cannot remove the front wheel hub/bearing assembly on my ford f350 4WD. Any suggestions. I'm using a slide hammer type puller and it just won't break free?
Aug 7, 2008 at 3:17 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:128f42b66e="mwhits"]Drive Train Axles Bearings problem
I cannot remove the front wheel hub/bearing assembly on my ford f350 4WD. Any suggestions. I'm using a slide hammer type puller and it just won't break free?[/quote:128f42b66e]
If I am not mistaking the hub assembly is Bolt On....
Question is did you remove the Bolts from the back side, there are 4.
If it happens to be Pressed in you will need a special tool for installing and removing the assembly. There is also a snap ring holding it in from the back side. So a slide hammer will not take it out.
Aug 7, 2008 at 3:32 PM
