Engine Mechanical problem
2000 Ford F350 V8 Two Wheel Drive Manual
when turned on the engine sounds like it has a lot of power but when you go out on the road the engine starts to fail and it stops to run we have replaced the fuel pump that goes in electrical chases and the problem is still the same we think that it only happens when when it is hot because when it cools it works fine
Mar 28, 2010 at 10:33 PM
