2000 Ford F-350 FUEL PRESSURE FEED LINE
2000 FORD F-350
KILLERKILO
Engine Performance problem
2000 Ford F-350 V8 Manual 200000 miles
I am expieriencing a heavy furl leak from what I believe to be the fuel pressure feed line. It is a 7.3ltr desiel, with a manual teanny. I was wondering if you guys had any scematics of the fuel system. The shop manual i ahve sucks and I would like to know were to start looking for this line. I cannot see it because it is stuffed between the firewall any the tranny. Any suggentions or any ideas of where else the fuel could be leaking? I know its not the fuel water separator because the valley is dry and the fuel filter area is dry.
Oct 15, 2010 at 2:02 AM
TECH1FORD
  • 102 POSTS
the fuel supply line comes up the front of the engine so I would think that it is the usually line under the turbo that has rubbed through, goes from the fuel bowl to the back of the right head you will see fuel running down the back of the engine due to the hole in the block for this.
Oct 25, 2010 at 7:32 PM
