Clutch adjustment
1999 FORD F-350
190,000 MILES • V8 • 2WD • MANUAL
HKMORPHIS
how do I adjust the clutch peddal so I do not have to go all the way to the floor?
Apr 11, 2010 at 9:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The clutch is not adjustable
The clutch control system consists of the above components.
The clutch control system engages and disengages the clutch system. The clutch control system disengages the clutch system when the clutch pedal is depressed and engages the clutch system when the clutch pedal is released. When the clutch pedal is depressed it pushes the clutch master cylinder plunger developing hydraulic pressure and applies the clutch slave cylinder which engages the clutch release lever and bearing. The clutch release bearing clutch release compresses the clutch pressure plate diaphragm spring, releasing the pressure on the clutch disc which in turn disengages the transmission from the engine.
The hydraulic clutch system adjusts automatically to compensate for clutch disc wear. Clutch linkage is not adjustable.
Check out this guide it will help you
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Apr 30, 2010 at 2:36 PM
