[quote:045b86e2f1="mhpautos"]Hi there,
Do you have clutch hydraulic pressure? if not check fluid & master cylinder for leaks as well. Start there.
Mark (mhpautos)[/quote:045b86e2f1]
Thanks for the response. I do have hydraulic pressure clutch. I got the vehicle into gear after pumping the clutch repeatedly by hand. Air in the line was the problem. Unfortunately, there is no bleeder valve so the only way to get air out of the system without replacing the complete system is to pump the pedal numerous times.
Jan 10, 2008 at 7:22 AM
