1999 Ford F-350 Powersteering
1999 FORD F-350
194,000 MILES • V8 • 4WD • AUTOMATIC
GREGWALLS
1999 fordf350 diesel can a bad brake booster effect my power steering
Oct 9, 2010 at 1:48 PM
DRCRANKNWRENCH1
  • 3,435 POSTS
I do not think that one could affect the other.
To check if a brake booster has failed, do the following;
Before starting the truck, pump the brake pedal till it is firm.
Next, keep your foot firmly pressed down on the brake and start your truck.
If the brake booster is OK, it will fall away under your foot and not be as firm.
Sounds wierd, but true.
The brake bosster uses vacuum to assist in decreasing the amount off pedal pressure it takes to stop the truck, thusly the drop in the pedal when starting your truck.
Some trucks do use air brakes and some off roaders even use hydrulically pressurized systems that us a pump just like a power steering pump. You can look at the bosster on your truck and see a vacuum line, about 1/2 in diameter or less, that leads to the manifold or some vacuum source.
If you are running big tires or carry heavy loads, power steering racks and pumps can wear out more quickly from the extra stress.
Check the power steering fluid.
Is it burnt or a dirty brown color?
Does it smell burnt?
Let me know how things go and I will check back to see what the fluid is looking like.
If your experiencing steering issues, it is probably the pump or rack. I will help all I can to get it figured out.
Oct 9, 2010 at 2:10 PM
TECH1FORD
  • 102 POSTS
your diesel has what is called a hydroboost which is the assist that runs the brakes and steering so a failed hydroboost can cause steering problems.It all depends on what is happening with the steering it is normal to be hard steering if you are not moving and your foot is on the brake.
Oct 9, 2010 at 10:47 PM
DRCRANKNWRENCH1
  • 3,435 POSTS
Okay, I have heard of these. One pump to pressurize steering and brakes.
Since the question was asked if they can affect each other, Ford Tech has answered that. There must be some problem that you have noticed with the brakes and steering that started at the same time.
Check the Hydro fluid, does it look or smeel burnt?
Look for luid leaks around the system. Lucas Power Steering stopleak is a good quick fix.
Do you hear any squealing noises coming from under the hood around the time the issue started?
What kind of problems are you experiencing?
Oct 10, 2010 at 12:24 AM
GREGWALLS
First started squeling but not that noticable when turning more so when engine rebed up. After a while got to where it was louder squeling and harder and harder to turn and brakes started to be soft when first pushed. I put new power steering pump on worked good about 3months steering and brakes ..Now same problems noticed small traces of fluid around hydrobooster. Thinking booster now should be replaced and hopeing did not mess steering pump .
Oct 10, 2010 at 9:17 AM
DRCRANKNWRENCH1
  • 3,435 POSTS
Yeah, sounds like the hydroboost needs to be replaced.
The squealing and leaks are a sure sign.
Let me know how it goes.
Oct 10, 2010 at 4:17 PM
