I lost brake fluid but it didn't leak out
1997 FORD F-350
180,000 MILES • V8 • 4WD • AUTOMATIC
GJSTARIHA
i lost brake fluid but it didn't leak out anywhere? is it possible it is in the vacuum tank behind the master cylinder? if so....what is the fix? do i need to replace the master cylinder? the brake and abs lights are on.
Feb 28, 2009 at 2:21 PM
SQM
  • 6,383 POSTS
If you are losing brake fluid, then it is due to a leak.
One of the most common leak area is the rear wheel cylinder. Those wheel cylinders have a tendency to leak out of the seal, and that will have brake fluid leaking inside the brake drum. Which can be difficult to see without removing the brake drum.
https://www.2carpros.com/articles/how-to-replace-a-wheel-cylinder
Keep in mind that replacing the wheel cylinders will require the brakes to be bled to purge out any trapped air.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Thank you.
Nov 9, 2021 at 9:52 PM
