Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-350
Body
Rear Window
Replace/Remove
1996 Ford F350 Drivers Side Rear Window Regulator Removal
1996 FORD F-350
160,000 MILES • V8 • 4WD • AUTOMATIC
[email protected]
MEMBER
1 POST
FOLLOW
How do you remove the drivers side rear window regulator
Sep 9, 2010 at 1:23 PM
BILLYMAC
CERTIFIED EXPERT
remove the door panel.
remove rubber window guide from top of door panel if equipped.
remove bolts holding glass to reg
block window up or remove.
remove bolts or rivets remove reg assy
Sep 19, 2010 at 9:40 AM
