bleed lines bench bleed master still has soft pedal
1995 FORD F-350
315,000 MILES • V8 • 2WD • AUTOMATIC
AUTOPRINC
MEMBER
1 POST
FOLLOW
front and rear pads and shoes,new master cylinder,and bleed lines bench bleed master still has soft pedal
Feb 17, 2010 at 8:26 AM
SQM
CERTIFIED EXPERT
There are few reasons to have soft pedal or pedal that goes to the floor. Of course, the most common reason is having air in the brake line. It can also be due to a leak.
Keep in mind that ABS brakes have different bleeding procedure and will require special tool to perform the task properly.
