you have a faulty clutch i'm afraid .. it needs replacing ... i suspect it's the pressure plate and it will only get worse ?
Slipping
Pressure springs worn or Release pressure plate
Oily, greasy or worn facings...Clean or replace clutch disc
Incorrect clutch alignment...Realign clutch assembly
Warped clutch disc or pressure plate....Replace damaged components
Binding release levers or clutch pedal...Lubricate and/or replace release components
Nov 29, 2008 at 9:01 PM
