1995 Ford F350 Shifting
1995 FORD F-350
153,000 MILES • V8 • 4WD • AUTOMATIC
PAPPI
I have an issue. The truck has a 12 inch lift. It has never shifted this way before until now. I t will shift perfect into2nd gear. Then the rpm's will rise to 4000, then shift real hard into 3rd gear. Everything else runs great. Any ideas?
Jul 31, 2008 at 6:26 PM
BMRFIXIT
  • 19,053 POSTS
What tranny do u have in it
possible shifter solenoid
scan for codes will hell
check tranny fluid
check vacuum lines for leaks and throttle cable and links
good luck
Jul 31, 2008 at 7:03 PM
PAPPI
I have reading up on this in the reapir manual i have. What do you think of the EEC. Since the EEC calculates speed and load conditions, then commands the actuators within the transmission to intiate shift. I have a 3 speed with overdrive transmission. Like i said the transmission shifts only hard in 3rd gear. I will check the vacuum modulator.
Jul 31, 2008 at 11:34 PM
