1992 Ford F350 Battery connections
1992 FORD F-350
202,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALICIA123
I have a question about the negative battery cable,One part of the negative hookup goes to the body and the other negative cable is not connected to anything, where does it go? It looks like it just came off.Can you please tell me where I need to connect this other long cable that comes from the negative battery connection?? Please let me know asap.Thank you so much for your time.
Mar 25, 2009 at 2:50 PM
2CARPRO JACK
  • 11,533 POSTS
usually one lead goes to the engine and the other to the body.If it has dual batteries, one neg lead may go to the other battery, then a single lead to the engien for both batteries
Mar 25, 2009 at 4:42 PM
ALICIA123
Where on the engine?Forgive my ignorance.Thanks so much.
Mar 26, 2009 at 12:37 PM
2CARPRO JACK
  • 11,533 POSTS
Straight to the cylinder head or block, either one as long as it is clean where you bolt it up and tight
Mar 26, 2009 at 3:02 PM
