1990 Ford F350 Engine won't crank
1990 FORD F-350
180,000 MILES • V8 • 4WD • AUTOMATIC
LAWDOG33
I recently obtained a 1990 F350 truck. The key was a little difficult to turn but it would crank and the engine would start and run fine. We had extreme low temperatures,( in the single digits), and when I tried to start the truck, the battery showed power but nothing happened when I turned the key. I tried jumping it but it still would not start. Any suggestions
Jan 3, 2008 at 12:50 PM
FISHERMAN
  • 937 POSTS
[quote:bd9c83b83a="lawdog33"]Engine problem
1990 Ford F350 V8 Four Wheel Drive Automatic 180000 miles
I recently obtained a 1990 F350 truck. The key was a little difficult to turn but it would crank and the engine would start and run fine. We had extreme low temperatures,( in the single digits), and when I tried to start the truck, the battery showed power but nothing happened when I turned the key. I tried jumping it but it still would not start. Any suggestions[/quote:bd9c83b83a]
Hello !!
could be a faulty starter, remove it and test it..
good Luck!
Jan 3, 2008 at 1:32 PM
