1988 Ford F350 testing
1988 FORD F-350
CE7181T
Engine Performance problem
1988 Ford F350 Four Wheel Drive Automatic
simple qustion, just bought the truck, had a new crate motor installed by ford 2 years ago, has 2000 miles on motor, previous owner was 84 years old, I was a mechanic for 30 years, although I still have the savy to figure it out I now longer have acess to alldata o a lab scope
when i do about 50 miles per hour and give it gas it does not seem to want to go and i noticed it seems to stumble, the fuel pressue is 40 psi , with 3 new pumps and filter, I suspect Ing. problem however cannot find the tests i need to check coil, or module restiance
Sep 4, 2010 at 12:26 PM
MERLIN2021
  • 17,250 POSTS
I will email you a copy of the diagnostic procedures, check your email. Could be the ignition module starting to fail...
Sep 4, 2010 at 1:45 PM
