I suspect the ignition section and need a schematic of the associated system.
I've cleaned all the connectors and occasionally can tap the connector area and the engine stops but it is intermittent.
Today I can not get the engine to start using all the normal tricks after changing the oil and filter.
If you know of a source of a detailed wiring schematic, I would appreciate it.
Thanks, PP
Thanks, PP
Apr 27, 2010 at 8:24 PM
