I have a 1997 Ford F-250, it has a 5.8 liter V-8 and it has approximately 117,000 miles. The truck runs fine when the lights are off. I have tried taking off the pos. battery cable to see if it was a problem with the alternator and the truck continues to run fine, it also runs fine when the parking lights are on,A/C is on, & radio is on. As soon as you turn on the lights though, it dies. I have installed a solenoid last week before the problem occurred and installed new battery terminals, I tried switching the wires around to see if that would solve the problem and that did not work. I changed out the light switch and noticed a couple wires melted and when I put those together the hazard lights tried working but did not blink (I also found out the hazards did not work when I found out the light did not work). Where should I begin looking for the short?
Jul 19, 2007 at 10:56 PM
