Vehicle is 1999 Ford F250 4x4 with about 79,000 miles. The manual says not to use a fluid for dual use such (Mercon and Mercon V). Specifications say to use Motorcraft Mercon ATF, can just Mercon V be used? Is the dual use they speak of the ability to use the fluid to replace something other than transmission fluid?
Thanks
Thanks
Mar 13, 2006 at 8:15 PM
