Sluggish, hesitant acceleration ('76 Ford F250 300 6 cyl.)
1976 FORD F-250
JOHN MCCLURE
I've recently reinstalled a stock Carter 1 barrel carb on my '76 Ford F250, 300 c.i. 6 cylinder (w/auto trans). The engine runs very well with one exception. When climbing up to freeway speed the engine goes through a sluggish hesitation till about midrange through each gear. As the engine nears normal operating temp the sluggishness decreases some but still is there. As a test I accelerated more aggressively to freeway speed and that makes the hesitation much less but of course driving it that way full time is out of the question. Once cruzing at freeway speed it runs fine. The idle is fine and the electric choke works as it should. The plugs are new and the air filter is new. I checked the vacuum to the distributor and that checks out. Any suggestions will be greatly appreciated.[size=18:295a4060ec][/size:295a4060ec][size=12:295a4060ec][/size:295a4060ec]
Jun 12, 2006 at 2:47 PM
BIG RED
Did you check fuel pump delivery and pressure. I owned a 76 f150 w/ 4 speed manual. I became 1 with that pickup ...best pickup
I ever owned. let me know if I can help ya.
Jun 12, 2006 at 3:09 PM
LUNGMAN
Sounds as if you have a fuel restriction problem, an accelerator pump discharge that is not correct ,or float level. Be sure the accelerator pump rod is adjusted correctly. You should be able to see steady squirt of fuel into the throttle body when you depress the throttle rod. Be sure your spark plugs have the proper gab about .35. If this does not help, be sure that your timing is correct, & the firing order is correct. Made that mistake myself years ago! Good luck.
Jul 5, 2006 at 10:58 AM
