IGNITION KEY STUCK
FORD F-250
RMCJR
I HAVE A 92 F250 DIESEL. I PULLED TH EPANELS IN FRONT OF THE SPEEDOMMENTER TO CHANGE SOME BULBS THAT HAD BURNED OUT.AFTER I PUT EVERYTHING BACK TOGETHER THE IGNITION KEY IS STUCK IN THE IGNITION AND THE KEY WILL NOT START THE TRUCK. IT WILL TURN TO THE ON POSITION BUTWILL NOT GO TO THE NEXT POSITION TO START. ALSO THE TRUCK IS AN AUTOMATIC WITH THE SHIFTER ON THE COLUMN.iTMOVES FREELY TO ANY POSITION
Jun 17, 2007 at 8:29 AM
JWALTH02
  • 180 POSTS
Do you have the shifter in Park? Cause that won't let it come out or start or anything either.
Jun 17, 2007 at 2:50 PM
