Hi I am having a strange brake problem with my 1994 Ford F250 Turbo Diesel IDI. It has 284000.0 KM, and the E4OD Auto Transmission. Everything seems fine once warmed up, but when cold at low speeds, only forward, the front brakes seem to grab hard making the whole front end shudder badly. When I stop completely, the brakes hold when released, and release after I start forcing the truck forward. It does not do it in reverse, and it grabs evenly not causeing a pull to one side or the other. It has dual piston calipers so I figured it may be the front piston grabing first causing a lock up, but it is confusing why it is happening evenly and not just one side? After warm up , it doesn't shudder, but still clunks when it grabs, and still holds at stop lights. But not in reverse? Why is it doing this, and why only in forward? Thanks in advance for any help you can provide.
Jan 5, 2007 at 11:03 AM
