abs light illuminated and brake lights are on
FORD F-250
SCOOTERD
I have a 1997 f-250 heavy duty, 4x4, E4od transmission (about 1000 miles on rebuild), approximately 25,000 on Jasper 5.8l. Yesterday the abs light came on and the brake lights are also staying on, I have to pull the fuse to get the brake lights to go out. I know absolutely nothing about the ABS system. Any help would be greatly appreciated.
Oct 23, 2007 at 7:23 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e39b58c4cb="scooterd"]I have a 1997 f-250 heavy duty, 4x4, E4od transmission (about 1000 miles on rebuild), approximately 25,000 on Jasper 5.8l. Yesterday the abs light came on and the brake lights are also staying on, I have to pull the fuse to get the brake lights to go out. I know absolutely nothing about the ABS system. Any help would be greatly appreciated.[/quote:e39b58c4cb]
check the brake fluid level
you may need a brake job
and if all ok you have to scan for code s
good luck
let us know
Oct 23, 2007 at 7:35 AM
SCOOTERD
Thank you for the quick response. The two problems are completely unrelated. The brake light switch went bad, I should have checked that prior to posting, as far as the ABS light, it went out so I still don't have a clue as to what caused it to go on.
Oct 24, 2007 at 9:30 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e2135986ef="scooterd"]Thank you for the quick response. The two problems are completely unrelated. The brake light switch went bad, I should have checked that prior to posting, as far as the ABS light, it went out so I still don't have a clue as to what caused it to go on.[/quote:e2135986ef]
every time you turn key on the system go throw a check list and if the switch was bad . this is why
good luck
Oct 24, 2007 at 11:56 AM
