89 ford 5.0 Water pump problem.
1989 FORD F-250
MAXON
while searching the internet trying to find a solution i have came to this website. i found a post submitted by someone else that is very similiar to my problem but the answer does not help me.
*****question i found******
Question: I have a 1989 Lincoln Continental with 125000 miles on it. Occasionally I will find some coolant under the car; it does not leak a lot. I checked all hoses, water pump and radiator but could not find any leak but I do see the timing chain cover is wet. Can you help me to solve this problem?
Answer: A leaking intake manifold gasket or timing chain cover gasket may be causing your coolant problem. Occasionally the chain cover corrodes and leaks.
*****my question/problem*****
my water pump is doing the same thing... its a 5.0 out of an 1989 mustang. Instead of just leaking a little out of the 2 back holes on the timing chain cover it is blowing huge amounts of water through when the engine comes up to temperature or is taken above 5000 rpm's. I have taken off/replaced the water pump gasket four times now and i get the same results everytime. i am very "car knolegable" but i cannot figure out why this is happening. everytime the gasket is being blown apart right where those 2 holes are at. both surfaces have been very clean each time i have replace the gasket. pleaaase help!! im tired of this problem. i can supply pictures if this is unclear. **this has nothing to do with the timing chain cover gasket, definatly water pump side** oh and yes, it is a new water pump
Jan 30, 2007 at 11:19 PM
SERVICE WRITER
  • 9,123 POSTS
Pics never hurt. There are different length bolts that need to be right if I remember. May have noting to do with it...
Jan 31, 2007 at 8:29 PM
MAXON
i'll take some pics today. im pretty sure i have all the right bolts in the right place, im using all originals but 1
Feb 3, 2007 at 3:17 PM
SERVICE WRITER
  • 9,123 POSTS
How did you clean the mating surfaces?
Feb 3, 2007 at 5:39 PM
