My power Steering pump went bad, and I replaced it with a Remanufactured pump, I have had to replace it 4 times total in the last 4 months or 5000 miles. My pump also works the Brakes. Now on the second pump I noticed that the steering was a little goofy. While driving the Steering will act like the Centering would go wierd and the Truck would skip over the center . I need to Stop the Truck and run the wheel From stop to stop , then the Steering is back to normal. Can The geer Box be the cause of Both of my problems, Is there a way to Clean the Gear box to remove Dirt from, Or would I need to get it Rebuilt. Also Is a rebuild Something posible to be done at my Home Garage?
Thank you For any help , The dealer won't give me any help except Drop it off and they will charge.
Nov 5, 2010 at 1:40 PM
