Battery Draining and Charging?
2005 FORD F-250
50,000 MILES • V8 • 4WD • AUTOMATIC
JAMMS24
Will it damage a battery to repeatedly let it drain (by leaving radio on for extended periods, et.,) and then jumping it off?
Thanks,
Aug 26, 2008 at 10:47 AM
You're ruining the battery: If the battery is allowed to run down (leaving the lights on, low charging output, slipping drive belt, frequent short-trip driving, long periods of inactivity, etc.), sulfate can form a barrier on the surface of the plates that makes it difficult for the battery to accept a charge. Over time, this can ruin the plates and cause the battery to fail.
And also the computer can lose its memory so you are going to have a bigger problem with the engine management system.
Aug 26, 2008 at 11:01 AM
