2004 Ford F250 Heater blows cold air
2004 FORD F-250
67,000 MILES • V8 • 4WD • AUTOMATIC
DANDDSCHULTZ2
My heater blows cold air when parked, but blows warmer when the vehicle is moving.
Dec 23, 2009 at 9:51 PM
JAYBIN82
  • 44 POSTS
are you low on coolant? if not you might have a air bubble in the coolins system, let the truck heat up to normal temp. you should have at least 1 bleeder valve. (by the thermostat, water pump, or on one of the lines from the heater core) open one or all the bleeder you find. they should spit a steady stream. so bleed untill it does, might have to close them shut off the truck let it cool and repeat. hope it helps
May 23, 2019 at 7:18 PM
