Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-250
Body
Door
Chime
2004 Ford F250 door controls
2004 FORD F-250
80,000 MILES • V8 • 4WD • AUTOMATIC
JOHNKC
MEMBER
FOLLOW
on my 2004 f250 the door chime headlight chime radio shutoff are all not working any suggestions ?
Jul 12, 2010 at 11:08 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
Hello and thanks for donating Check fuse # 41 (10 amp) in the central junction box. The CJB is located under the driver's side of instrument panel.
Jul 13, 2010 at 5:27 PM
JOHNKC
MEMBER
Jul 14, 2010 at 7:05 AM
JOHNKC
MEMBER
If it is not the fuse what else can i try?
Jul 14, 2010 at 7:06 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
If it isn't the fuse then there is most likely some wiring that is damaged or loose behind the door panel .
Jul 14, 2010 at 10:45 AM
