2003 Ford F250 trouble codes what they mean
2003 FORD F-250
167,000 MILES • V8 • 4WD • AUTOMATIC
RACEFAN39
If I can get the truck to run it runs very poorly and shacks very badly here are the codes that I retrieved from the computer po138,po284,po400,p1000 I don't understand what po284 code means please explain what these codes would make the truck do
thank-you
Jan 26, 2010 at 8:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
P0138, is for a problem with an O2 sensor Pos wire short to earth or a faulty sensor.
P0284 Cyl 8 low power possibly an injector fault.
P0400 EGR system fault.
P1000, P1000 is not actually a trouble code. It just means that the Readiness code has not been set yet or in other words, the engine computer hasn't completed testing certain emission control components. If there is no other problems with the car emission system, the code P1000 will disappear after driving for some time (the drive cycle must include idling, stop and go traffic, acceleration and steady cruising).
Mark (mhpautos)
Jan 26, 2010 at 9:17 PM
BMRFIXIT
  • 19,053 POSTS
Is it diesel !
should start with
a compression test
Jan 26, 2010 at 9:21 PM
