2003 Ford F250 fuse #45
2003 FORD F-250
100,000 MILES • V8 • 2WD • AUTOMATIC
STYMIED101
Number 45 fuse keeps blowing. It is 10 amps. All the gauges stop working and the battery does not charge. Now the fuse stops blowing and no charge or gauges. TY
Jun 19, 2009 at 4:05 PM
MERLIN2021
  • 17,250 POSTS
Has the truck been scanned for codes yet? You need this as a first step, the circuits involved are:
Accelerator pedal possition sensor, Clutch pedal possition switch, instrument cluster, Auxilliary powertrain control module, overdrive cancel switch, and the four wheel drive control module...needs to be narrowed down some...scan first.
Jun 20, 2009 at 4:34 AM
STYMIED101
It is a 2 wheel drive. It is a automatic also. I found a short today in the overdrive/shift lever. I replaced it. It stopped blowing fuses but still has no gauges nor the battery has stopped charging. No codes.
Jun 20, 2009 at 7:12 PM
MERLIN2021
  • 17,250 POSTS
Have you checked the power distribution center? The fuse box under the hood? Also is this an electronic display dash or analog?
Jun 20, 2009 at 7:38 PM
MERLIN2021
  • 17,250 POSTS
Instrument Cluster Self-Diagnostic Mode To enter the instrument cluster self diagnostic mode with the engine off, depress and hold the odometer reset button. Turn the ignition switch to the RUN position and hold until the gauges sweep (within five to eight seconds). Depress the reset button once to advance to each stage of the self-test. Turn the ignition to the OFF position to exit the instrument cluster self -diagnostic mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics. Post up all codes that pop!
Jun 20, 2009 at 7:50 PM
STYMIED101
No fuses under hood. Anolog not electronic. I tried the Instrument Cluster Self-Diagnostic Mode(ICSDM). The instruments do not sweep nor respond in any fashion.
Jun 21, 2009 at 7:02 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_150fuses_2.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_150fusesb_1.jpg
There are several fuses for the IP, did you check all? Central box has three! 2, 16, and 30....
Jun 22, 2009 at 1:52 PM
