2003 Ford F250 Ball joint replacement
2003 FORD F-250
DILLONVOLPAUTOMOTIVE
Suspension problem
2003 Ford F250 V8 Four Wheel Drive Automatic
I am doing new ball joints they are trashed. I have the bearing out of this 4 wheel drive but how do I get the axle out? It has a "seal" that is in the was around the axle near the the end by the shaft outside wise. I am not sure what to do to get it out to pull the spindle out. 2003 F-250 4x4
Mar 26, 2009 at 1:15 AM
BMRFIXIT
  • 19,053 POSTS
axle have to be out before you can remove the spindle out
spindle must come out for ball joint replacement
Mar 26, 2009 at 6:13 AM
