I have a 6.0 diesel. The truck runs fine when cold, but after it gets hot it misses and seems to be starving for gas around 1500rpm. If I step on it it picks up a little.I changed the fuel filters and a ford dealer changed the EGR valve and installed an injector control pressure sensor. The problem is still there. Is this a turbo problem, if so would a rebuild kit help? Ford said the turbo was fine and all computer checks show no problems (maybe readings were done when cold).
Aug 8, 2009 at 6:47 PM
