2002 Ford Ranger 12mpg?
2002 FORD F-250
SHAKIEH31
Hello, I have a 2002 Ford Ranger Edge 3.0L w/ automatic transmisison. There are a few things wrong with the vehicle but I'm almost sure they all tie into the same thing. I get around 12 miles to the gallon and I'm pretty sure that's not right. The engine often seems underpowered and requires around 2500-3000 rpm's to keep up with traffic. However, this changes day by day. There is also pinging when the engine is under load such as climbing a hill or accelerating in second gear. I'v been struggling with this for months and have replaced many things including all oxygen sensors. The engine seems to run better after I clean some carbon out of it by getting on the throttle. However, the mpg never really gets better. It has been as low as 8 mpg before. Any help or suggestions? They would be much appreciated! Thanks!
Tony
Feb 24, 2006 at 11:18 PM
PEPPERMRJ
  • 1,158 POSTS
Run some injector cleaner thru a couple of tanks of gas. I would also take a good look at the knock sensor. Check the connection and the sensor it self. They also must be installed with the correct torque to function properly.
Any codes?
Feb 25, 2006 at 2:51 PM
