2002 Ford F250 overdrive shifting
2002 FORD F-250
245,666 MILES • V8 • 4WD • AUTOMATIC
DP1176
In cool weather it shifts fine but as soon as it has gotten warm out it does not shift into overdrive. I was told that the transmission needs rebuilt but I can't understand that it works fine in the cold but not as soon as ithe weather warms. Also it can sit all day in 70 to 80 degree weather and as soon as I start it up the trans temp gauge is already up to operating temp. The lock out button does flash on and off without touching it, and will not go out by depressing the button.
Apr 6, 2010 at 8:14 PM
LEGITIMATE007
  • 5,121 POSTS
its quite possible that the oil cooler is not working efficiently, or may be partially clogged, i would first try doing a tranny service, flush the fluid, change the filter. before ripping it down, also check the temperature sending unit, it may be faulty and triggering these other problems
Apr 7, 2010 at 10:07 PM
