2001 Ford F250 code PO175
2001 FORD F-250
PUNKCATS
Engine Performance problem
2001 Ford F250 V8 Two Wheel Drive Automatic
yes i have a question on my econoline van.
I did a dianostic and it shows up a code PO175.
I already replace both oxygen scensors and MAF scensor and still getting the misfire, when I turned up the key.
I would appreciated if you can give any ideas on what to check and possibly the problem.
thanks
Nov 18, 2009 at 2:38 PM
MERLIN2021
  • 17,250 POSTS
Can be a shotr to ground of one of the 02 sensors, or the compuvalve, a PDF is in your mail box!
Nov 18, 2009 at 2:56 PM
AJVANDYKE
  • 36 POSTS
Two other thing to check for that could be part of the problem: If there is a vaccum leak it can also cause a misfire. Or it could possibly be a fuel injector that is clogged or a little plugged up.
Nov 18, 2009 at 3:04 PM
MERLIN2021
  • 17,250 POSTS
P0175 is a rich code for bank 2 if anything to do with the injectors, it leaking or putting out too much fuel. I think the spec on them is 11-18 ohms across the injector terminals.
Nov 19, 2009 at 2:34 AM
