2001 Ford F-250 Signal to COP7 stays steady, bad computer?
2001 FORD F-250
110,000 MILES • V12 • 4WD • AUTOMATIC
HAYEDID
I got an engine code P0357, and determined that I had a bad Coil over Plug (COP). I bought a new one, installed it and it smoked and burned within 10 seconds.
I purchased a new coil (COP) and spark plug, but I don't feel comfortable hooking them up yet.
I did a 12 volt light test on the input to this COP (#7 / G) and the light stays steady (no flashing) and is very bright. (before I put in the new coil that burned, the input was flashing).
Well, now that the coil input is steady, I know the coil won't work. This is computer controlled. Does this mean I need a new computer. Is there something else that can be replaced that actually produces the flashing 12 v signal or does it come directly from the computer? What is the computer called? Where is it located? Am I looking an an ECM, PCM, or something else?
Thank you.
Oct 7, 2010 at 8:37 PM
TECH1FORD
  • 102 POSTS
the computer controls the ground side of the coils so if the light stays on all the time it means that there is a short inside the pcm. the computer is located on the drivers side panel below the dash beside the e-brke pedal undo the 10mm bolt on connector under the hood on the fire wall and the 2 bolts inside the truck and it comes right out
Oct 10, 2010 at 12:07 AM
HAYEDID
Thank you.
Oct 10, 2010 at 12:20 AM
WRENCHTECH
  • 20,761 POSTS
Before jumping to the conclusion of have a bad PCM, you first need to eliminate the possibility that the wire connecting the coil to the PCM is shorted to ground which is more likely than a bad PCM. Unplug the PCM and measure continuity to ground from that wire when disconnected from the coil..
Oct 10, 2010 at 6:17 AM
