1999 Ford F250 truck stutters when applying light accelerat
1999 FORD F-250
140,000 MILES • V8 • 4WD • AUTOMATIC
MATTANDLULA
i have a 99 ford f-250 v10. when i'm maintaining speed w/ light acceleration on the pedal the truck will stutter and will go away if i gas it or let off the gas. i'm thinking it may be the MAF sensor going bad? you thoughts?
Jan 19, 2010 at 3:04 PM
1996F250
try replacing your fuel filter, my 96 f250 was doing the same thing and that seemed to do the trick. after you remove the old one blow into it, if there is resistance when you blow then it needs to be replaced. while your at the store ask for a fuel filter removal kit, you will need it.
Jan 23, 2010 at 9:26 PM
