Engine Mechanical problem
1999 Ford F250 V8 Four Wheel Drive Automatic
hi, this is sam ryan and i am the owner of a 1999 ford f250 lariat. my truck has been shaking is at a low and sort of ruff idle. also the codes that i have been recieving from the engine computer suggest that bank two is lean on fuel. i suspect that it is either the coolant temp. sensor or the mass airflow sensor. i have also tried running the truck without the MAF sensor (mass air flow sensor) and it seemed to run fine but it might just be me. and when i check the continuity of the MAF it tells me that it might be bad. but the book that i have relied on for years i now showing me things that dont match my engine. if you could also tell me where to find the coolant temp sensor.
i will check this thread later tonight.
thanks,
sam
thanks,
sam
Dec 30, 2009 at 3:20 PM
