There are a number of things that can cause this, but we need to start with these couple of guides because the most likely cause is the head gasket has failed.
Take a look at these guides and let us know what you find with this:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Basically, if it were me, I would jump to checking the block with the chemical block testing that is shown in that guide above.
Once we know this info, we can determine the next steps. I suspect the engine overheated at some point and if that is the case then I am pretty sure you have a head gasket issue.
Please run through this and let us know what you find. Thanks
Jan 29, 2022 at 6:30 PM
