1999 Ford F250 ford f250 v8
1999 FORD F-250
REDTEXAN
Engine problem
1999 Ford F250 180458 miles
my truck was running fine then all of a sudden it bogges down while driving. I can give it alot of gas and it will go.I changed the fuel filter and it still does it please help
Jan 8, 2008 at 9:04 AM
SERVICE WRITER
  • 9,123 POSTS
Was there a lot of sediment in the filter?
Can you check the fuel pressure when the problem is happening to verify it is fuel related?
Jan 8, 2008 at 9:32 AM
REDTEXAN
[quote:1f0b72d35e="Service Writer"]Was there a lot of sediment in the filter?
Can you check the fuel pressure when the problem is happening to verify it is fuel related?[/quote:1f0b72d35e]how would i go get that checked?
Jan 8, 2008 at 10:05 AM
SERVICE WRITER
  • 9,123 POSTS
The filter you could have tapped out the sediment on the return side, but it is probably too dry at this point.
The fuel prssure can be checked by attaching a fuel gauge to the test port, and running the gauge up to the windshield and taping it there so you can monitor t while your moving.
Jan 8, 2008 at 11:07 AM
