1998 Ford F250 Hazard warning lights
1998 FORD F-250
45,000 MILES • V8 • 2WD • AUTOMATIC
GRAHAM MCLEOD UK
Direction indicators work fine. Hazard lights work on right hand side only.
Any one can help with wiring diagram. Fuses seem OK.
Feb 21, 2008 at 3:36 PM
MASTERTECHTIM
  • 4,750 POSTS
the hazards run through the directional switch. the directional switch is bad.
Feb 21, 2008 at 3:37 PM
GRAHAM MCLEOD UK
[quote:b6951cda02="mastertechtim"]the hazards run through the directional switch. the directional switch is bad.[/quote:b6951cda02]
Thanks for immediate response - So you are saying its not the hazard switch but what we call the indicator switch (down-left up-right) even though they functions as indicators ok
Much appreciated will fill in the report bit when I have worked it out
Feb 21, 2008 at 3:58 PM
MASTERTECHTIM
  • 4,750 POSTS
yes the turn signal switch in the steering column. when you turn left and right there are little fingers that slide across a circuit board inside the switch. there are 2 sets of fingers, one for the turn and one for the hazards. thats why your turn signals still work. those fingers are ok.
Feb 21, 2008 at 4:02 PM
