1997 Ford F250 Fuel gauge, one tank empty, one tank full
1997 FORD F-250
259,000 MILES • V8 • 2WD • AUTOMATIC
NSENYK117
  • 22 POSTS
My front tank stays at empty. If I unplug the sending unit the gauge then goes past full. If I leave it plugged in and cut the ground wire and splice in another and run it to ground the gauge goes past full. Bad sending unit for the front tank? My rear tank was also staying empty and not moving. I unplugged the sending unit and it went past full on the gauge. I spliced in a wire and went to ground and now the gauge reads past full when I have the rear tank on? Both wires I used were the smaller of the 4, the yellow and white I think. Do I have 2 bad sending units?
Sep 18, 2010 at 9:03 PM
KHLOW2008
  • 41,814 POSTS
Hi nsenyk117,
Thank you for the donation.
The Yellow/White wire is correct for the sending units but in our database it is stated as Yellow/White up to the fuel tank selector switch and beyond that, the rear fuel tank should be Yellow/Blue whereas the front fuel tank is Dark Blue/Yellow.
Where did you unplug the sending unit connectors and grounded it?
One thing that seems out of place is the gauge showing past full when the connector is unplugged. Under normal curcumstances the gauge should drop to empty when the sending unit is unplugged.
Sep 18, 2010 at 11:41 PM
NSENYK117
  • 22 POSTS
At frst I unplugged the sending unit at its electrical plug in connector. I then tried to ground the female end of the plugin to the truck. The key was in the run position. As soon as I unplug the connector the fuel gauge goes all the way full. To avoid this I left it plugged in to keep the tank reading empty and cut the yellow/white wire on the sending unit side of the electrical connction. Then splicing it to another wire and running it to the negative side of the battery the gauge moves all the way past full again. Also, with the key in the run position, I put my test light into the female ends on the wiring harness side of the connectors to test for power, it never lit up on all 4 wires. The truck will run and use the fuel from both tanks. If i unplug the connector and try to start the truck it wont so it must work for the pump. Why do both tanks read all the way past full when the electrical plug in to the sending units is unplugged? Would it have anything to do with the dome light coming onvery time the brakes are pushed?
Sep 19, 2010 at 7:18 AM
NSENYK117
  • 22 POSTS
Here is what I have for the wiring at the front tank. Sending unit side Wiring harness side Black Black Black/PinkRed Gray/RedOrange Yellow/WhiteYellow/Blue
https://www.2carpros.com/forum/automotive_pictures/338784_f150fuelsending_1.jpg
Sep 19, 2010 at 7:55 AM
KHLOW2008
  • 41,814 POSTS
That kept me wondering. If the connector is unplugged, the fuel gauge should not move from bottom of gauge.
Plug in the connectors. Turn ignition ON and then OFF again. Unplug the connector and then turn ignition switch ON. Does the gauge reading go past Full?
Problem seems to be from gauge rather than sensing unit.
With connector unplugged, test the resistance between the Yellow/White of sending unit connector and body ground. Is resistance between 5 to 100 ohms?
If possible, get 2 different resistor of 10 and 50 ohms. Connect either one in series between the Yellow white wires and turn on ignition switch. Note gauge reading. Change resistor and retest.
Sep 19, 2010 at 8:04 AM
NSENYK117
  • 22 POSTS
With the connector plugged in its empty. With it unplugged its pegged past full. When I press the brakes the dome light comes on and when I open the drivers door the dome light does not come on. Do you think this could all be related? It appears the guy before me had speaker stuff hooked up. I found a cut aftermarket wire run into the fuse panel. Do these systems share the same wiring?
Sep 19, 2010 at 8:46 AM
KHLOW2008
  • 41,814 POSTS
For the fuel gauge to register Empty, the sending unit must be providing a high resistance, most probably in the region of 100 to 105 ohms to ground.
In this instance, it could be a bad/poor ground that is increasing the resistance.
This could be related to the interior lights coming on when the brake pedal is depressed. Check the ground circuit at rear taillights. Clean and retighten them to see if the problem is resolved.
The driver door not operating the dome light could be due to a faulty door switch.
Sep 19, 2010 at 9:24 AM
NSENYK117
  • 22 POSTS
I found the ground under the drivers side tailight. It had 2 white wires to the frame. I cleaned it up and nothing. I replaced the door jamb switch and nothing. The passenger side does work however, always did. The fuel gauges are the same. Im going to bring my meter home tommorow and check the ohms. The dome light still comes on when breaking. It appears to me that the passenger side door jamb switch wiring runs along the dash into the fuse box and then to the drivers side switch. Could a bad gauge do all of this?
Sep 19, 2010 at 6:36 PM
KHLOW2008
  • 41,814 POSTS
A faulty meter is not likely to cause the symptoms described and I believe it could be a bad ground for the meter assembly.
Check the ground circuits at :
1. Behind bottom of left kick panel.
2. Left front of engine compartment, on upper radiator support.
Is your vehicle equipped with keyless entry?
Does the warning system for the door chime module works when the headlights are left on with ignition switch turned off?
Is your vehicle model heavy or light duty?
Sep 20, 2010 at 12:52 PM
NSENYK117
  • 22 POSTS
Both grounds are good. No keyless entry. No, the door chime doesnt work at any time. Heavy Duty model. After dinner I am going to check ohms. Would a bad tank selector do this?
Sep 20, 2010 at 5:04 PM
NSENYK117
  • 22 POSTS
Ok, I got under the truck with my meter. With the key off I tested the Black and Blue/Yellow wire on the wiring harness side of the midship tank. I got 155 ohms. Then I went from the yellow/white wire to the gas tank as my ground on the midship tank 1494 ohm. I could not produce any results with the rear tank. I tried both the ways as the midship tank and switched the fuel to rear tank, nothing.
Sep 20, 2010 at 7:22 PM
KHLOW2008
  • 41,814 POSTS
At driver door jamb switch, test for battery voltage at Light Green/Yellow wire. If voltage is not available, you have a broken connection between the Fuse # 8 ( 15 A ) and the door jamb switch.
Apply battery voltage to the Black/Light Blue wire and check if the dome light comes on.
Apply battery voltage to the Red/Pink and note if the chime works.
Did you unplug the wireharness while performing resistance test?
Sep 21, 2010 at 10:41 AM
NSENYK117
  • 22 POSTS
OK, we are making progress. I applied voltage to the black/light blue wire and the dome light did come on. The chime did not. Yes, I unplugged the wire harness plug at the sending unit before resistance testing. Im going to search for the broken wire. Im going to guess that the kid before me may have tied his radio stuff into these wires for power?
Sep 21, 2010 at 4:39 PM
NSENYK117
  • 22 POSTS
I have power coming into and going out of fuse #8. I dont see any cuts, splices, or breaks. The fuse panel is directly above the door jamb sensor, the wire cant be that long unless it goes into the instrument cluster? I removed the tank selector switch and jumped the terminals with the same results so it must not be the problem. I have 8 volts at the tank selector. I filled the mid tank this morning on my way to work. Of course it still read E. I dont work far from home and didnt use much fuel. I pulled the truck in the garage to start my wire search tonight and it went to F? The rear tank still nothing. It looks like it may be a legitimate Full, its on the line not past it. What is the deal with this thing?
Sep 21, 2010 at 6:57 PM
KHLOW2008
  • 41,814 POSTS
To search for broken wires, the best is to test the continuity. Some wires break internally and might look good.
Do you have battery voltage at the Green/Yellow wire?
I do not understand the fuel gauge problem. If the connector to the sending unit is unplugged, the gauge should show Empty if the ignition switch is turned ON. You indicated it is going up past Full. This indicates a fault with the gauge or its wiring. Possibly the gauge ground is insufficient.
8 volts at the tank selector doesn't mean anythnig as the power is from the gauge and after going through the coil inside the gauge, it can drop.
Does the gauge show full when the selector is unplugged?
Use a 20 ohm resistor to ground the selector wire and check if the gauge shows any reading.
Sep 22, 2010 at 8:41 AM
