Brakes problem
1997 Ford F250 V8 Four Wheel Drive Automatic 126K miles
Same problem as other Ford owners have experienced that I read about on your site. Dragging pads on front rotors still after the following part replacements: NEW master cylinder, new front lft rotor and caliper assembly, new front brake hoses, new Bendix pads ( both wheels), checked wheel bearings for wear/play. Left side drags worse than right side. Re- bled system twice( when I bled the r.a.b.s. valve, the fluid in it was very milky) Lubed caliper bolts and checked booster rod clearance before installing new master cylinder.Third set of pads and two rotor changes in 6,000 miles! Dagging seems to be worse after this round of repairs! There is only two parts left in the system I have not replaced yet- The booster and /or the r.a.s.b. valve. Not sure if they are part of the solution???
Dec 8, 2008 at 6:03 PM
