1996 Ford F250 No ignition key
1996 FORD F-250
168,376 MILES • V8 • 2WD • MANUAL
STUMPY1958
I have to replace the steering column in my truck due to the bearings in the column being worn out and was going to reuse my ignition switch in the old column for the new replacment. I do not have the key for the ignition switch to turn it to the "run" postion to extract the switch for the new replacment which I got from the bone yard. How do I get the Ig. Switch without a key. Is there a easy out?
Apr 11, 2009 at 7:32 AM
DAVE H
  • 13,384 POSTS
you will have to drill out the old lock barrel ...
Apr 11, 2009 at 7:55 AM
