1995 Ford F250 will fire from coil but from cap it won't
1995 FORD F-250
LARRYEDWARD
Electrical problem
1995 Ford F250 V8 Two Wheel Drive Automatic
what is wrong when you don't get fire from the cap but you do from the coil
Aug 26, 2010 at 10:54 PM
If its coming out of the coil not at the sparkplug thoroughly inspect the cap and rotor or just replace both-also the rotor might not be spinning due to a sheared drive gear or the component that drives the distributor
Aug 26, 2010 at 11:47 PM
