1994 Ford F250 Hard Shifting SOMETIMES
1994 FORD F-250
150,000 MILES • V8 • 4WD • AUTOMATIC
WBONEBRAKE
In my 94 F250, sometimes I can start it up and drive it, with no problems. Most of the time though, when I start it, it revs up way too much before shifting, then slams into gear. The next few gears only engage when I slightly let off the gas. Also, sometimes when I start it, it seems to be missing at first, but when I drive it for a few seconds, the motor is running fine. Any clues as to what may be wrong? Thanks a lot.
Bill
Jun 4, 2010 at 5:59 AM
MERLIN2021
  • 17,250 POSTS
There is a tech bulletin on the transmission range switch, check it for water intrusion into the switch and replace it with Ford Part #F5TZ-7A247-A.
Jun 4, 2010 at 8:23 PM
