1994 Ford F250 DASH LIGHTS ,TAIL LIGHTS, POWER WINDOWS ,POW
1994 FORD F-250
154,905 MILES • V8 • 2WD • AUTOMATIC
MICHAEL MENDENHALL
I HAVE HAD MY TRUCK FOR 4 MONTH IT WAS FINE UP UNTILL A MONTH AGO . THE WINDSHELD WIPERS AND DOOR LOCKS POWER WINDOW AND RADIO WOULD CUT OUT AND STOP WORKING . CAN'T FIND THE PROUBLEM. NOW THE TRUCK WON'T START. I CHECKED THE GROUND TO THE BATTERY TO THE FRAME OF TRUCK .THAT WAS OK I REPLAECED THE BATTERY IT HAS RAN FOR 4 DAYS ADN IT HAS GONE BACK TO NOT STARTING . I HAVE NO RUNNING LIGHTS WHAT IS THE PROBLEM . I HAVE HAD IT WITH THIS THING .
Feb 18, 2009 at 9:14 PM
BOWTIE BABY
  • 101 POSTS
If you havent already, check all fuses and relays and body ground wires. it sounds like it is probably a loose wire some where, either power or ground. Check all wires and fusible links coming of of the starter solenoid, Thats where the truck gets its power from for the fuse box and acceseries, good luck,
Votes and feedback are appreciated.
Feb 19, 2009 at 12:27 AM
