I'm trying to pull my engine and am stuck. All accessories and cables removed. Disconnected the exhaust from the exhaust manifold. Removed 6 bolts between engine and transmission (bell housing). Removed lower cover plate, starter and 4 bolts from flywheel to torque convertor. I removed the bolts from the engine mounts. I can lift the engine up and expect the transmission to breakaway but it doesn't. I have a Transmission Jack under the transmission and lowered the eng/tran on it thinking they would separate - but still no luck. I have never had this problem before - what am I missing.
Oct 13, 2009 at 1:01 PM
