the abs light just came on and will not go out
1994 FORD F-250
MARTY BROWN
  • 6 POSTS
hello, and thank you for your help. the abs light just came on and will not go out. also, the off light on the shifting column for the overdrive is blinking all the time. the engine is the 7.3 deisel. can you tell me how to repair the problem? thank you
Aug 27, 2010 at 4:47 PM
WRENCHTECH
  • 20,761 POSTS
Those lights being on indicate that the computer has sensed a malfunction and stored a trouble code. Reading the codes is the proper way to approach this but judging by the symptoms, you likely have a bad speed sensor in the top of the differential.
Aug 27, 2010 at 5:18 PM
MARTY BROWN
  • 6 POSTS
Thank you for your reply. Is this something I could repair myself? Special tools etc. What kind of scanner should I get.
Aug 27, 2010 at 7:03 PM
WRENCHTECH
  • 20,761 POSTS
Yes, it's very simple, just held in by one bolt.
Aug 27, 2010 at 7:04 PM
