1991 Ford F250 Oil Pump
1991 FORD F-250
140,000 MILES • V8 • 4WD • AUTOMATIC
TOEMOSS
1. How I determine if the oil pump is faulty?
2. If it is faulty, what are the steps to remove and replace the oil pump?
May 28, 2008 at 1:50 PM
MERLIN2021
  • 17,250 POSTS
Unscrew the oil sening unit near the filter, and screw in a pressure test gauge, take the readings at Idle you will have on a warm engine, about 10psi, raise engine speed to 2000 RPM, reading should be 40-60 psi, if it's too low, or too high, further work is in order...
May 28, 2008 at 1:55 PM
