1990 Ford F250 fogged / wet windshield
1990 FORD F-250
MCERCONE
Interior problem
1990 Ford F250 V8 Two Wheel Drive Automatic tmu miles
the interior of the windshield gets so fogged up, the defroster on high doesn't help at all. The truck has no a/c
Sep 29, 2008 at 2:54 PM
BLACKOP555
  • 10,386 POSTS
oily substance on the windshield? does any air come out of the vents? smell like antifreeze?
Nov 22, 2008 at 6:52 PM
MCERCONE
it doesn't seem oily, more like condensation. the fan works, air blows thru vents, but does not get hot. I'm leaning toward heater core problem and looking for info on how to check and/or replace core.
Nov 28, 2008 at 10:18 AM
BLACKOP555
  • 10,386 POSTS
to check it you can disconnect the heater core hoses and pressurize it. will it hold the pressure or does it leak out?
Nov 29, 2008 at 10:31 AM
SILENTFOREVER_04
  • 12 POSTS
If it is blowing a mist out of your vents then it is most likely your heater core. I am not sure on newer trucks, but I have both a 89 and 92 Ford truck and the heater core on both trucks is in the same spot. It is behind the glovebox, inside the dash. It is a pretty easy replacement. Took me about 15 min. And it was only about $30. Another thing you could check is to make sure that your radiator has plenty of water in it. The heater core uses the heated engine water to heat the air so if you are low in water your heater will not heat the air. Good luck
Dec 11, 2008 at 9:17 AM
BLACKOP555
  • 10,386 POSTS
yes it is behind the glovebox, and it really does sound like a heater core issue to me.
up till 93 or 94 was when the heater core was behind the box, after that you get to dismantle the dash to get to it.
bring in the old heater core, some part stores give out the wrong ones that will fit but when you go to put the hoses on there is no way it will work.
Dec 13, 2008 at 9:16 AM
